Failed to download metadata for repo 'apnscp-testing'
Hey there,
getting an error while trying to update:
TASK [network/setup-firewall : Update firewalld packages] *******************************************************************************************************************************************************************************************************************************************
fatal: [localhost]: FAILED! => {“changed”: false, “msg”: “Failed to download metadata for repo ‘apnscp-testing’: Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried”, “rc”: 1, “results”: }
PLAY RECAP ******************************************************************************************************************************************************************************************************************************************************************************************
localhost : ok=1555 changed=10 unreachable=0 failed=1 skipped=702 rescued=0 ignored=0
  • What version of apnscp are you running?
    cpcmd misc_cp_version
    revision: 5c064d4530eecc5b167049e024fc6bc5b0600f97
    timestamp: 1744336756
    ver_patch: 46
    ver_pre: 6-g5c064d453
  • Which version of RHEL or CentOS are you using?
    cat /etc/redhat-release
    AlmaLinux release 8.10 (Cerulean Leopard)
  • Can you reproduce this bug reliably? Provide steps. If not, provide steps to the best of your recollection.
    (upcp --reset)
    upcp -sb
Update policy is major.
Thanks and best regards
That looks to be a transient network error. I’m able to connect OK:
dnf --disablerepo='*' --enablerepo='apnscp-testing' list
