Hi there, trying to install a fresh Apis Instance fails with
2024-12-12 11:00:29,622 p=584364 u=root n=ansible | TASK [/usr/local/apnscp/resources/playbooks/roles/software/pyenv/../pyenv-support : Clone pyenv repository] ***
2024-12-12 11:00:30,332 p=584364 u=root n=ansible | fatal: [localhost]: FAILED! => {"changed": false, "cmd": "/bin/git checkout --force v1.2.4", "msg": "Failed to checkout v1.2.4", "rc": 1, "stderr": "error: pathspec 'v1.2.4' did not match any file(s) known to git\n", "stderr_lines": ["error: pathspec 'v1.2.4' did not match any file(s) known to git"], "stdout": "", "stdout_lines": []}
2024-12-12 11:00:30,337 p=584364 u=root n=ansible | PLAY RECAP *********************************************************************
2024-12-12 11:00:30,338 p=584364 u=root n=ansible | localhost : ok=1587 changed=11 unreachable=0 failed=1 skipped=719 rescued=0 ignored=0
2024-12-12 11:00:34,742 p=595718 u=root n=ansible | PLAY [localhost] ***************************************************************
Changing /usr/local/apnscp/resources/playbooks/roles/software/pyenv-support/defaults/main.yml back to
- pyenv_repo: https://github.com/apisnetworks/pyenv
+ pyenv_repo: https://github.com/pyenv/pyenv
allows the installation to finish but is obviously not as intended.
