- What version of apnscp are you running?
revision: ca92487ad55c94763dc5ee86356589136e86246e
timestamp: 1762907856
- Which version of RHEL or CentOS are you using?
Rocky 10
- Can you reproduce this bug reliably? Provide steps. If not, provide steps to the best of your recollection.
When running upcp -b this error has popped up. Executing dnf install cockpit -y finds the package without problems, installs it and after that the ansible script runs through without problems.
included: /usr/local/apnscp/resources/playbooks/roles/system/yum/tasks/enable-auto-updates-dnf.yml for localhost
included: /usr/local/apnscp/resources/playbooks/roles/common/tasks/implicitly-import-overrides.yml for localhost
included: /usr/local/apnscp/resources/playbooks/roles/software/imagick/tasks/set-xml-element.yml for localhost
included: /usr/local/apnscp/resources/playbooks/roles/software/watchdog/tasks/enable-watchdog.yml for localhost
included: /usr/local/apnscp/resources/playbooks/roles/apnscp/install-services/tasks/template-service.yml for localhost
included: /usr/local/apnscp/resources/playbooks/roles/apnscp/install-services/tasks/install-service.yml for localhost
TASK [software/cockpit : dnf] **********************************************************************************************************************************************************************************************************************************************************
fatal: [localhost]: FAILED! => {"changed": false, "failures": ["cockpit* - No result for argument: cockpit*"], "msg": "Failed to install some of the specified packages", "rc": 1, "results": []}
PLAY RECAP *****************************************************************************************************************************************************************************************************************************************************************************
localhost : ok=1222 changed=30 unreachable=0 failed=1 skipped=686 rescued=1 ignored=0
Iām not able to reproduce this on Rocky 10.1
Run this command twice to trigger the bug (or however you were invoking it previously). Provide the full output or PM it to me for further examination.
upcp -sbvv software/cockpit
# ansible --version
ansible [core 2.16.14]
config file = /etc/ansible/ansible.cfg
configured module search path = ['/root/.ansible/plugins/modules', '/usr/share/ansible/plugins/modules']
ansible python module location = /usr/lib/python3.12/site-packages/ansible
ansible collection location = /root/.ansible/collections:/usr/share/ansible/collections
executable location = /usr/bin/ansible
python version = 3.12.12 (main, Oct 10 2025, 00:00:00) [GCC 14.3.1 20250617 (Red Hat 14.3.1-2)] (/usr/bin/python3)
jinja version = 3.1.6
libyaml = True
Running this cmd for a 2nd time seems to have fixed the error.
