php fails to load in virtual site
Getting a load error when executing php in a virtual site -
chroot /home/virtual/site1/fst /usr/bin/php -v
/usr/bin/php: error while loading shared libraries: libfido2.so.1: cannot open shared object file: No such file or directory
From the standard file system -
/usr/bin/php -v
PHP 8.4.21 (cli) (built: May 30 2026 14:47:51) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.4.21, Copyright (c) Zend Technologies
    with Zend OPcache v8.4.21, Copyright (c), by Zend Technologies
Thanks for the bug report. Run upcp, fixed on edge for EL9+ platforms.
Now we get
/usr/bin/php: error while loading shared libraries: libcbor.so.0.11: cannot open shared object file: No such file or directory
What’s the operating system value from hostnamectl?
Operating System: AlmaLinux 10.2 (Lavender Lion)
         CPE OS Name: cpe:/o:almalinux:almalinux:10.2
      OS Support End: Fri 2035-06-01
OS Support Remaining: 9y
              Kernel: Linux 6.12.0-211.7.3.el10_2.x86_64
        Architecture: x86-64
Got it. upcp once more. :+1:
Excellent. Thanks!
I have this same error on Rocky 10.2.
Operating System: Rocky Linux 10.2 (Red Quartz)
CPE OS Name: cpe:/o:rocky:rocky:10::baseos
OS Support End: Thu 2035-05-31
OS Support Remaining: 8y 11month 3w 5d
Kernel: Linux 6.12.0-124.40.1.el10_1.x86_64
/usr/bin/php -v
PHP 8.4.21 (cli) (built: Jun 1 2026 00:27:43) (NTS)
It’s fixed in edge. You’ll need to be on edge for the fix to apply otherwise the error persists.
See Upgrading | ApisCP Docs
not sure if it is related:
PLAY RECAP *********************************************************************
localhost                  : ok=13   changed=0    unreachable=0    failed=1    skipped=12   rescued=0    ignored=0
STDERR:
[/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:212]
         0. Lararia\Database\Migrations\PlatformMigrator->runMigration("2026_02_09_105615_rspamd-autolearn", "up", [step:true])
            [/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:129]
         1. Lararia\Database\Migrations\PlatformMigrator->runUp("/usr/local/apnscp/resources/playbooks/migrations/2026_02_09_105615_rspamd-autolearn.yml", 5, false)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:165]
         2. Illuminate\Database\Migrations\Migrator->runPending(["/usr/local/apnscp/resources/playbooks/migrations/2026_02_09_105615_rspamd-autolearn.yml", "/usr/local/apnscp/resources/playbooks/migrations/2026_04_30_000001_cve-2026-31431.yml", "/usr/local/apnscp/resources/playbooks/migrations/2026_05_30_111720_el10-libfido2-dep.yml"], [pretend:false, step:0, rollback:false, ff:false])
            [/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:93]
         3. Lararia\Database\Migrations\PlatformMigrator->runPending(["/usr/local/apnscp/resources/playbooks/migrations/2026_02_09_105615_rspamd-autolearn.yml", "/usr/local/apnscp/resources/playbooks/migrations/2026_04_30_000001_cve-2026-31431.yml", "/usr/local/apnscp/resources/playbooks/migrations/2026_05_30_111720_el10-libfido2-dep.yml"], [pretend:false, step:0, rollback:false, ff:false])
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:110]
         4. Illuminate\Database\Migrations\Migrator->run(["/usr/local/apnscp/resources/playbooks/migrations"], [pretend:false, step:0, rollback:false, ff:false])
            [/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:41]
         5. Lararia\Database\Migrations\PlatformMigrator->run(["/usr/local/apnscp/resources/playbooks/migrations"], [pretend:false, step:0, rollback:false, ff:false])
            [/usr/local/apnscp/lib/Lararia/Console/Commands/PlatformMigration.php:76]
         6. Lararia\Console\Commands\PlatformMigration->handle()
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:36]
         7. Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/Util.php:37]
         8. Illuminate\Container\Util::unwrapIfClosure()
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:93]
         9. Illuminate\Container\BoundMethod::callBoundMethod(Lararia\Application, [], [Lararia\Console\Commands\PlatformMigration, "handle"], )
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:35]
        10. Illuminate\Container\BoundMethod::call(Lararia\Application, [], [Lararia\Console\Commands\PlatformMigration, "handle"], null)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/Container.php:596]
        11. Illuminate\Container\Container->call([Lararia\Console\Commands\PlatformMigration, "handle"])
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Command.php:134]
        12. Illuminate\Console\Command->execute(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/symfony/console/Command/Command.php:298]
        13. Symfony\Component\Console\Command\Command->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Command.php:120]
        14. Illuminate\Console\Command->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/symfony/console/Application.php:1040]
        15. Symfony\Component\Console\Application->doRunCommand(Lararia\Console\Commands\PlatformMigration, Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/symfony/console/Application.php:301]
        16. Symfony\Component\Console\Application->doRun(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/symfony/console/Application.php:171]
        17. Symfony\Component\Console\Application->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Application.php:93]
        18. Illuminate\Console\Application->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Application.php:184]
        19. Illuminate\Console\Application->call("migrate:platform", [--force:true, --pretend:false], Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:263]
        20. Illuminate\Foundation\Console\Kernel->call("migrate:platform", [--force:true, --pretend:false], Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php:261]
        21. Illuminate\Support\Facades\Facade::__callStatic("call", ["migrate:platform", [[--force:true, --pretend:false], Illuminate\Console\OutputStyle]])
            [/usr/local/apnscp/lib/Lararia/Console/Commands/Migrate.php:55]
        22. Lararia\Console\Commands\Migrate->handle()
        23. Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
        24. Illuminate\Container\Util::unwrapIfClosure()
        25. Illuminate\Container\BoundMethod::callBoundMethod(Lararia\Application, [], [Lararia\Console\Commands\Migrate, "handle"], )
        26. Illuminate\Container\BoundMethod::call(Lararia\Application, [], [Lararia\Console\Commands\Migrate, "handle"], null)
        27. Illuminate\Container\Container->call([Lararia\Console\Commands\Migrate, "handle"])
        28. Illuminate\Console\Command->execute(Symfony\Component\Console\Input\ArgvInput, Illuminate\Console\OutputStyle)
        29. Symfony\Component\Console\Command\Command->run(Symfony\Component\Console\Input\ArgvInput, Illuminate\Console\OutputStyle)
        30. Illuminate\Console\Command->run(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
        31. Symfony\Component\Console\Application->doRunCommand(Lararia\Console\Commands\Migrate, Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
        32. Symfony\Component\Console\Application->doRun(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
        33. Symfony\Component\Console\Application->run(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
        34. Illuminate\Console\Application->run(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:129]
        35. Illuminate\Foundation\Console\Kernel->handle(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
            [/usr/local/apnscp/lib/Lararia/Console/Kernel.php:31]
        36. Lararia\Console\Kernel->handle(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
            [/usr/local/apnscp/artisan:58]
I cannot assist you if you do not provide the full output of the failed migration. So far you’ve provided a traceback from the code that initiates migrations, not the migration itself.
Top half:
Compiled services and packages files removed!
Nothing to migrate.
Migrating: 2026_02_09_105615_rspamd-autolearn
PLAY [localhost] ***************************************************************
TASK [common/migrate : Locate migration files] *********************************
included: /usr/local/apnscp/resources/playbooks/migrations/2026_02_09_105615_rspamd-autolearn.yml for localhost => (item=Running 2026_02_09_105615_rspamd-autolearn)
TASK [Install EL9/EL10 deps] ***************************************************
TASK [Install EL10 deps] *******************************************************
TASK [apnscp/initialize-filesystem-template : Install zlib-ng-devel into FST/ssh] ***
fatal: [localhost]: FAILED! => {"changed": false, "cmd": ["/usr/local/apnscp/bin/php-bins/php", "/usr/local/apnscp/bin/scripts/yum-post.php", "install", "zlib-ng-devel", "ssh"], "delta": "0:00:00.176560", "end": "2026-06-03 17:35:54.521780", "failed_when_result": true, "msg": "non-zero return code", "rc": 1, "start": "2026-06-03 17:35:54.345220", "stderr": "ERROR  : CLI\\Yum\\Synchronizer\\Utils::getFilesFromRPM(): failed to enumerate package `zlib-ng-devel'\n         0. Error_Reporter::add_error(\"failed to enumerate package `%s'\", [\"zlib-ng-devel\"])\n            [/usr/local/apnscp/lib/log_wrapper.php:72]\n         1. error(\"failed to enumerate package `%s'\", \"zlib-ng-devel\")\n            [/usr/local/apnscp/lib/CLI/Yum/Synchronizer/Utils.php:175]\n         2. CLI\\Yum\\Synchronizer\\Utils::getFilesFromRPM(\"zlib-ng-devel\")\n            [/usr/local/apnscp/lib/CLI/Yum/Synchronizer/Install.php:89]\n         3. CLI\\Yum\\Synchronizer\\Install->run()\n            [/usr/local/apnscp/bin/scripts/yum-post.php:21]\nERROR: CLI\\Yum\\Synchronizer\\Utils::getFilesFromRPM(): failed to enumerate package `zlib-ng-devel'", "stderr_lines": ["ERROR  : CLI\\Yum\\Synchronizer\\Utils::getFilesFromRPM(): failed to enumerate package `zlib-ng-devel'", "         0. Error_Reporter::add_error(\"failed to enumerate package `%s'\", [\"zlib-ng-devel\"])", "            [/usr/local/apnscp/lib/log_wrapper.php:72]", "         1. error(\"failed to enumerate package `%s'\", \"zlib-ng-devel\")", "            [/usr/local/apnscp/lib/CLI/Yum/Synchronizer/Utils.php:175]", "         2. CLI\\Yum\\Synchronizer\\Utils::getFilesFromRPM(\"zlib-ng-devel\")", "            [/usr/local/apnscp/lib/CLI/Yum/Synchronizer/Install.php:89]", "         3. CLI\\Yum\\Synchronizer\\Install->run()", "            [/usr/local/apnscp/bin/scripts/yum-post.php:21]", "ERROR: CLI\\Yum\\Synchronizer\\Utils::getFilesFromRPM(): failed to enumerate package `zlib-ng-devel'"], "stdout": "", "stdout_lines": []}
(4d69713e-eb3d-543c-8478-19f0591d48d7 RuntimeException) EXCEPTION: STDOUT:
fatal: [localhost]: FAILED! => {"changed": false, "cmd": ["/usr/local/apnscp/bin/php-bins/php", "/usr/local/apnscp/bin/scripts/yum-post.php", "install", "zlib-ng-devel", "ssh"], "delta": "0:00:00.176560", "end": "2026-06-03 17:35:54.521780", "failed_when_result": true, "msg": "non-zero return code", "rc": 1, "start": "2026-06-03 17:35:54.345220", "stderr": "ERROR  : CLI\\Yum\\Synchronizer\\Utils::getFilesFromRPM(): failed to enumerate package `zlib-ng-devel'\n         0. Error_Reporter::add_error(\"failed to enumerate package `%%s'\", [\"zlib-ng-devel\"])\n            [/usr/local/apnscp/lib/log_wrapper.php:72]\n         1. error(\"failed to enumerate package `%%s'\", \"zlib-ng-devel\")\n            [/usr/local/apnscp/lib/CLI/Yum/Synchronizer/Utils.php:175]\n         2. CLI\\Yum\\Synchronizer\\Utils::getFilesFromRPM(\"zlib-ng-devel\")\n            [/usr/local/apnscp/lib/CLI/Yum/Synchronizer/Install.php:89]\n         3. CLI\\Yum\\Synchronizer\\Install->run()\n            [/usr/local/apnscp/bin/scripts/yum-post.php:21]\nERROR: CLI\\Yum\\Synchronizer\\Utils::getFilesFromRPM(): failed to enumerate package `zlib-ng-devel'", "stderr_lines": ["ERROR  : CLI\\Yum\\Synchronizer\\Utils::getFilesFromRPM(): failed to enumerate package `zlib-ng-devel'", "         0. Error_Reporter::add_error(\"failed to enumerate package `%%s'\", [\"zlib-ng-devel\"])", "            [/usr/local/apnscp/lib/log_wrapper.php:72]", "         1. error(\"failed to enumerate package `%%s'\", \"zlib-ng-devel\")", "            [/usr/local/apnscp/lib/CLI/Yum/Synchronizer/Utils.php:175]", "         2. CLI\\Yum\\Synchronizer\\Utils::getFilesFromRPM(\"zlib-ng-devel\")", "            [/usr/local/apnscp/lib/CLI/Yum/Synchronizer/Install.php:89]", "         3. CLI\\Yum\\Synchronizer\\Install->run()", "            [/usr/local/apnscp/bin/scripts/yum-post.php:21]", "ERROR: CLI\\Yum\\Synchronizer\\Utils::getFilesFromRPM(): failed to enumerate package `zlib-ng-devel'"], "stdout": "", "stdout_lines": []}
I’m seeing provisioning splits. @Troy had something similar; which provider (i.e. how’d this come into being)? Which OS? This can be gleaned from reading /etc/redhat-release.
dnf install -y zlib-ng will allow this to proceed
Rocky Linux release 10.2 (Red Quartz)
Dont know what happened. Server hasn’t been touched in 3-4 months. Got a ping from my monitoring tools that one of my sites went down. Spent 30 mins troubleshooting why and found this issue, then came here and searched for the missing package that wouldn’t allow PHP to start.
Fixed it, 30 minutes later, another site went down. (PHP workers must die and restart every few weeks or months…?) Have ~20 sites on this box and all others are fine right now.
Hi - Was this fixed? or a path foward?
As noted above
