# cat /etc/redhat-release
Rocky Linux release 8.10 (Green Obsidian)
# uname -a
Linux myhost.example.com 4.18.0-553.22.1.el8_10.x86_64 #1 SMP Wed Sep 25 09:20:43 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
After new deployment of ApisCP and transferring/migrating sites from another (fully up-to-date) ApisCP host, I’m now getting the below Cron error email every 5 minutes.
PHP Fatal error: During inheritance of ArrayAccess: Uncaught ArgumentCountError: Too few arguments to function Horde_ErrorHandler::errorHandler(), 4 passed in /.socket/php/pear/Horde/Registry/Hordeconfig.php on line 24 and exactly 5 expected in /.socket/php/pear/Horde/ErrorHandler.php:153
Stack trace:
#0 /.socket/php/pear/Horde/Registry/Hordeconfig.php(24): Horde_ErrorHandler::errorHandler(8192, 'Return type of ...', '/.socket/php/pe...', 90)
#1 /.socket/php/pear/Horde/Autoloader.php(128): include('/.socket/php/pe...')
#2 /.socket/php/pear/Horde/Autoloader.php(65): Horde_Autoloader->_include('/.socket/php/pe...')
#3 /.socket/php/pear/Horde/Registry.php(1763): Horde_Autoloader->loadClass('Horde_Registry_...')
#4 /.socket/php/pear/Horde/Registry.php(480): Horde_Registry->importConfig('horde')
#5 /.socket/php/pear/Horde/Registry.php(287): Horde_Registry->__construct(0, Array)
#6 /usr/bin/horde-alarms(23): Horde_Registry::appInit('horde', Array)
#7 {main} in /.socket/php/pear/Horde/Registry/Hordeconfig.php on line 24
Fatal Error:
Stack trace:
#7 {main}
In /.socket/php/pear/Horde/Registry/Hordeconfig.php on line 24
1. Horde_ErrorHandler::catchFatalError()
Pretty sure Horde is kinda dead and not supporting PHP 8, which should be base version on Apis. I’d suggest you to disable it on both nodes, and maybe attempt transferring the site again if you ran into errors…
After disabling horde and running upcp -sbf mail/webmail-horde:
# cpcmd scope:set cp.bootstrapper horde_enabled false
# upcp -sbf mail/webmail-horde
PLAY [localhost] ********************************************************************************************************************************
included: /usr/local/apnscp/resources/playbooks/roles/mail/webmail-horde/tasks/configure-horde.yml for localhost
[WARNING]: flush_handlers task does not support when conditional
PLAY RECAP **************************************************************************************************************************************
localhost : ok=20 changed=0 unreachable=0 failed=0 skipped=7 rescued=0 ignored=0
I’m still getting all the same horde errors via cron daemon:
+Horde_ErrorHandler::errorHandler(), 4 passed in /.socket/php/pear/Horde/Registry/Hordeconfig.php on line 24 and exactly 5 expected in
+/.socket/php/pear/Horde/ErrorHandler.php:153
Stack trace:
Fatal Error:
Stack trace:
#7 {main}
