With the following policy map, OPcache config is only partially applied.
global:
version: '8.3'
workers: 10
governor: ondemand
idle_timeout: 300s
threads: 5
backlog: 60
connect: 30s
resources: { file_size: 4G, oom_adjust: 500 }
php_settings: { memory_limit: 1G, opcache.memory_consumption: 768M, opcache.jit_buffer_size: 500000000, opcache.jit: tracing, opcache.interned_strings_buffer: 16, opcache.max_accelerated_files: 1048793 }
privatetmp: null
log: { level: error, slow_threshold: 0, slow_log: null }
pools: null
blacklist: null
whitelist: null
Any chance to get those options changed?
On a side note, running the following command breaks the php.ini as path is further navigated to form a map in the file, failing with and array to string conversion.
cpcmd php:pool-set-policy site10 php_settings.opcache.memory_consumption 256M
Perhaps a bit more generic command could accept generic options instead:
cpcmd php:pool-set-policy site10 php_settings <key> <value>
cpcmd php:pool-set-policy site10 php_settings opcache.memory_consumption 256M
How are you applying these options? Do you have an override for the template in config/custom?
If I take your data, then run EditDomain --reconfig site1, the following is generated:
; Create a file named config/custom/resources/templates/apache/php/partials/fpm-config-custom.blade.php
; to add any additional directives after this line. These will override any php_admin_value settings
; within here or in a policy map.
php_admin_value[memory_limit] = 1G
php_admin_value[opcache.memory_consumption] = 768M
php_admin_value[opcache.jit_buffer_size] = 500000000
php_admin_value[opcache.jit] = tracing
php_admin_value[opcache.interned_strings_buffer] = 16
php_admin_value[opcache.max_accelerated_files] = 1048793
; Values imported from PHP-FPM policy map take precedence
php_value[session.save_path] = /tmp
And these values are correctly reflected in a PHP-FPM script:
<?php echo implode("\n",array_map(static fn($v, $k) => "{$k} => " . json_encode($v), ini_get_all(), array_keys(ini_get_all())));
opcache.interned_strings_buffer => {"global_value":"16","local_value":"16","access":4}
opcache.max_accelerated_files => {"global_value":"1048793","local_value":"1048793","access":4}
opcache.memory_consumption => {"global_value":"768M","local_value":"768M","access":4}
Thanks for the bug report. This is fixed in edge. API signature remains the same.
Indeed that’s what is generated in the php.ini, but that’s not reflected in the phpinfo.
php_admin_value[memory_limit] = 512M
php_admin_value[opcache.memory_consumption] = 128M
php_admin_value[opcache.interned_strings_buffer] = 8
php_admin_value[opcache.max_accelerated_files] = 16229
Resulting in opcache.jit still being function. I’ll double-check the numbers tho, but I did go for the --reconfig after each edit…
Looks related to PHP bug #80450.
Add a file to site10/fst/etc/phpXX.d/ named lexicographically higher than 01-opcache.ini to overwrite the jit type, then restart the pool.
