Database backup tasks are configured via Databases > MySQL Backups (or PostgreSQL Backups). Each database includes 2 backup tasks by default. You can snapshot and export these databases via Databases > MySQL (or PostgreSQL) Manager > List Users and Databases.
To backup a site, the easiest option is to copy /home/virtual/siteNN/info + shadow. info/ is the account metadata and shadow/ is its data layer. If you’re logged in as the site owner and want to take a quick snapshot of the filesystem (or a directory), then Files > File Manager > Download Directory is what you want.
grep -A5 MODULE_MARKER /etc/httpd/conf/httpd.conf - look for a LoadModule phpX_module line. Earlier releases of Apache obliterated on upgrade. Other sites that depend upon PHP would also fail
Does /tmp/dos-IP-ADDRESS exist? Where IP-ADDRESS is your IP address of course. You might’ve hit brute-force that temporarily disallows connections
cpcmd config_get apache.evasive + cpcmd config_get apache.evasive-whitelist would be relevant
Will download and rebuild PHP as well as update Apache configuration. rpm -qi httpd - what version does it list and when did things last work? Sounds like an Apache upgrade, but the last one was from February 25 and by all accounts it should carry over the LoadModule directive to load PHP.
You have new mail in /root/Mail
[root@server ~]# rpm -qi httpd
Version : 2.4.38
Release : 2.5.apnscp
Architecture: x86_64
Install Date: Tue 26 Feb 2019 09:59:27 PM PST
Group : System Environment/Daemons
License : Apache License, Version 2.0
Signature : RSA/SHA1, Tue 26 Feb 2019 03:10:59 AM PST, Key ID 3f9dd9ce321f362d
Source RPM : httpd-2.4.38-2.5.apnscp.src.rpm
Build Date : Tue 26 Feb 2019 03:09:50 AM PST
Build Host : dolly.apisnetworks.com
Relocations : (not relocatable)
Vendor : Apache Software Foundation
URL : http://httpd.apache.org/
Summary : Apache HTTP Server
Description :
Apache is a powerful, full-featured, efficient, and freely-available
Web server. Apache is also the most popular Web server on the
Internet.
@msaladna I’m trying to use MXroute as relay, using user@domain:password, give me error message:
MESSAGE SUMMARY
Reporter level: ERROR
ERROR: password is not present in credentials
Pro licensing, which has no limit on the number of domains or accounts is $20 per month per VM. I target 250 accounts, each of which has ~3 domains on average. At that point your per domain unit cost is $0.02 per domain per month or less. If you were to go with a Startup license that has a domain cap of 50, then your per domain cost is $0.08 per domain month.
As a rule of thumb I recommend building out 250-300 accounts on a 16-24 GB VM. You’ve enough slack to handle surges and distribute your risk across multiple servers. Node failures happen.
The magic comes once you price out third-party licenses that are core features of ApisCP.
Softaculous ($1.50/month) already built into ApisCP’s Web App module, which launched Update Assurance yesterday. UA performs stepwise content-length and HTTP status checks during updates, rolling back if aberrations are noted.
CloudLinux ($14/month) already built into ApisCP. All accounts are jailed to synthetic roots, a feature of ApisCP since its birth in 2002. Resource enforcement, just like in CloudLinux, is powered by cgroups - a native kernel feature.
Immunify360 ($45/month) Malware scrubs, DDoS prevention are managed through Rampart in ApisCP. A mod_security hook filters file uploads and sends an alert to block offending IPs.
MailChannels ($69/month) - or any smart-host. If you have enough servers and enough diversity in mail, ApisCP can communicate over an rspamd cluster that provides excellent spam mitigation. Clustering is a turnkey feature in Bootstrapper. Set rspamd_redis_server as part of mail/rspamd.
$20 per month versus $1.50 + $14 + $45 + $69/n = $129 + BYOL ($???), $20/month is a steal for the features you get. All of these components are integrated with precision; there’s less noise and fewer remarkable events because everything is vetted by real world testing through my hosting business as well.
