redis_running returns null even when Redis instance is running
Issue Report: redis_running returns null even when Redis instance is running
  • apiscp version: 3.2.0-dd42bbbfc (revision: dd42bbbfc6b78229069f0ab93e6b9aea6e44efa7)
  • OS version: Linux 6.12.0-124.31.1.el10_1.x86_64
  • Redis/Valkey: Valkey 8.0.6 (Redis compatibility 7.2.4)
  • Debug mode: enabled
Can you reproduce this bug reliably?
Yes, consistently reproducible.
# 1. Create Redis instance
cpcmd -d test.com redis_create "test"
# Returns: 1 (success)
# 2. List instances - shows instance exists
cpcmd -d test.com redis_list
# Returns:
# test:
#   port: 40011
#   bind: 127.0.0.1
#   unixsocket: null
#   type: tcp
# 3. Check if running - returns empty (null)
cpcmd -d test.com redis_running "test"
# Returns: (empty)
# 4. Verify process is actually running
ss -tlnp | grep :40011
# Returns: LISTEN 0 511 127.0.0.1:40011 0.0.0.0:* users:(("redis-server",pid=872036,fd=8))
The Problem
The Redis instance is running (verified via ss -tlnp), but redis_running returns null.
Root Cause
The PID file contains a different PID than the actual running process:
# PID file contains:
cat /home/virtual/site1/fst/home/testuser/.redis/test/redis.pid
# Returns: 872104
# Actual running process:
ps aux | grep redis-server
# Returns: testuser 872036 ... redis-server 127.0.0.1:40011
The redis_running function reads PID 872104 from the file, but pidMatches(872104, 'redis-server') returns false because process 872104 doesn’t exist. The actual Redis process is running with PID 872036.
Additional Observations
  1. redis_stop also fails because it relies on the same PID file:
cpcmd -d test.com redis_stop "test"
# Returns: WARNING: Instance `test' not running
  1. redis_start reports success but may silently fail if the port is already in use by the orphaned process.
  2. redis_version throws an exception:
strtok(): Argument #1 ($string) must be of type string, null given
[/usr/local/apnscp/lib/modules/redis.php:360]
This appears to be because getFullVersionFromPackage('redis') returns null when Valkey is installed instead of Redis.
  • redis_running should return the correct PID when the instance is running
  • redis_stop should be able to stop the running instance
  • redis_version should handle Valkey installations
Suggested Investigation
The issue may be related to how the PID is captured when Redis daemonizes. The daemonize: yes option causes Redis to fork, and it appears the wrong PID (parent instead of child) is being written to the pidfile.
Thank you for looking into this.
Thanks for the bug report. This is fixed in edge. If you’re not already on edge, you may switch to it temporarily:
Panel code may be updated by running upcp.
Thanks it fixes the issue @msaladna
@msaladna PTAL
i am calling redis_running soap apis in my node backend, i can see it now returns pid in server but the soap api is still returning nil true… here are the details
redis_running SOAP API returns null even when Redis instance is running
Summary
The redis_running SOAP method returns xsi:nil="true" (null) even when the Redis instance is actively running with a valid PID. The same call via cpcmd correctly returns the PID.
  • apiscp panel
  • SOAP API via WSDL
  1. Create a Redis instance named “test2”
  2. Start the Redis instance
  3. Verify it’s running via CLI:
cpcmd -d example.com redis:running "test2"
# Returns: 998070 (PID)
  1. Make the same call via SOAP API:
SOAP Request:
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/"
               xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
               xmlns:tns="urn:net.apnscp.api"
               xmlns:tm="http://microsoft.com/wsdl/mime/textMatching/">
  <soap:Body>
    <tns:redis_running>
      <name>test2</name>
    </tns:redis_running>
  </soap:Body>
</soap:Envelope>
SOAP Response:
<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"
                   xmlns:ns1="http://xml.apache.org/xml-soap"
                   xmlns:ns2="redis_running_Response"
                   xmlns:ns3="urn:net.apnscp.api"
                   xmlns:xsd="http://www.w3.org/2001/XMLSchema"
                   xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/"
                   SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
  <SOAP-ENV:Header>
    <ns2:Messages>
      <ns1:Map>
        <item><key>message</key><value>Key `save' already present, overwriting</value></item>
        <item><key>errno</key><value>1</value></item>
        <item><key>severity</key><value>DEBUG</value></item>
      </ns1:Map>
      <!-- ... more debug messages ... -->
    </ns2:Messages>
  </SOAP-ENV:Header>
  <SOAP-ENV:Body>
    <ns3:redis_runningResponse>
      <return xsi:nil="true"/>
    </ns3:redis_runningResponse>
  </SOAP-ENV:Body>
</SOAP-ENV:Envelope>
The SOAP response should return the PID (integer) when the Redis instance is running:
<return xsi:type="xsd:int">998070</return>
The SOAP response returns null (xsi:nil="true") even though the instance is confirmed running.
WSDL Definition
According to the WSDL, redis_running should return an integer:
<message name="redis_running_request">
    <part name="name" nillable="false" type="xsd:string" />
</message>
<message name="redis_running_response">
    <part name="return" type="xsd:int" />
</message>
Additional Context
  • The SOAP call is made using a valid session ID obtained via admin_hijack
  • Other Redis SOAP methods like redis_list work correctly and return data
  • The debug messages in the SOAP header (Key 'save' already present, overwriting) are identical to those shown in cpcmd, suggesting the method is being invoked correctly
  • This might be a permissions issue where the SOAP session context cannot read the PID file that cpcmd (running as root) can access
Thanks for the bug report. Fixed :+1:
