When sending mail true webmail
when we want to send the mail message we’re getting: SMTP-fout (451): Ontvanger "<emailadres>" kan niet toegevoegd worden (4.3.0 <emailadres>: Temporary lookup failure).
Also in the dashboard im getting red services: authlib and postgres
I don’t know if it has anything to do with it but I also get the following message: cannot update repo 'rspamd': repomd.xml GPG signature verification error: Bad GPG signature
I see this in the cockpit software update screen
Updating to v3.2.45
error: The following untracked working tree files would be overwritten by checkout:
apps/example/LICENSE
apps/example/application.yml
apps/example/test.js
apps/example/test.php
apps/example/test.tpl
apps/maillog/LICENSE
apps/maillog/application.yml
apps/maillog/maillog.php
apps/maillog/maillog.tpl
apps/mime/LICENSE
apps/mime/application.yml
apps/mime/mime.php
apps/mime/mime.tpl
apps/search/LICENSE
apps/search/application.yml
apps/search/search.php
apps/search/search.tpl
Please move or remove them before you switch branches.
Aborting
upcp halted due to errors
The mail error is, I believe, related to the posgresql error that popped up this morning. See Broken Postgres - #2 by anatoli for a temporary workaround. If you stop apiscp (and stop monit so that it doesn’t restart apiscp) then you can restart postgresql, and finally postqueue -f and your mail should flow again.
Loading available updates failed
Please resolve the issue and reload this page.
Oops
The software powering this discussion forum encountered an unexpected problem. We apologize for the inconvenience.
Detailed information about the error was logged, and an automatic notification generated. We’ll take a look at it.
No further action is necessary. However, if the error condition persists, you can provide additional detail, including steps to reproduce the error, by posting a discussion topic in the site’s feedback category.
