Ran cpcmd scope:set cgroup.version 2 and the VM rebooted.
Running EditDomain --reconfig --all as suggested in scope’s output the following error is thrown:
[root@web6 ~]# EditDomain --reconfig --all
WARNING: file_put_contents(/sys/fs/cgroup/site2/cpuset.cpus): Failed to open stream: Permission denied
[/usr/local/apnscp/lib/Opcenter/System/Cgroup/Attributes/Cpuset/Cpus.php:78]
0. file_put_contents("/sys/fs/cgroup/site2/cpuset.cpus", "0-3")
1. Opcenter\System\Cgroup\Attributes\Cpuset\Cpus->deactivate()
[/usr/local/apnscp/lib/Opcenter/System/Cgroup/Controllers/Cpuset.php:62]
2. Opcenter\System\Cgroup\Controllers\Cpuset->setAttribute(Opcenter\System\Cgroup\Attributes\Cpuset\Cpus)
[/usr/local/apnscp/lib/Opcenter/System/Cgroup/BaseController.php:215]
3. Opcenter\System\Cgroup\BaseController->import(Auth_Info_User)
[/usr/local/apnscp/lib/Opcenter/Provisioning/Cgroup.php:133]
4. Opcenter\Provisioning\Cgroup::createControllerConfiguration(Opcenter\SiteConfiguration)
[/usr/local/apnscp/lib/Opcenter/Service/Validators/Cgroup/Enabled.php:61]
5. Opcenter\Service\Validators\Cgroup\Enabled->reconfigure(1, 1, Opcenter\SiteConfiguration)
[/usr/local/apnscp/lib/Opcenter/Service/ReconfigurationCallback.php:65]
6. Opcenter\Service\ReconfigurationCallback->update("service.success", Opcenter\SiteConfiguration)
[/usr/local/apnscp/lib/Event/Manager.php:187]
7. Event\Manager->fire("service.success", Opcenter\SiteConfiguration)
[/usr/local/apnscp/lib/Event/Cardinal.php:172]
8. Event\Cardinal::fire(["service", "success"], Opcenter\SiteConfiguration)
[/usr/local/apnscp/lib/Opcenter/Account/Edit.php:155]
9. Opcenter\Account\Edit->installServices()
[/usr/local/apnscp/lib/Opcenter/Account/Edit.php:88]
10. Opcenter\Account\Edit->exec()
[/usr/local/apnscp/bin/EditDomain:119]
WARNING: Mail::_sendSMTP(): smtp auth failed: SMTP server does not support authentication, falling back to local mailer
INFO : Edited 5 sites in 3.35s (0.67s each) 5 succeeded, 0 failed, 0 skipped.
Note: re-running this command throws out no error. Perhaps this is due to some borked config dangling from cgroupv1.
Following blocks came through email:
Cpus.php: file_put_contents():78
WARNING: file_put_contents(/sys/fs/cgroup/site2/cpuset.cpus): Failed to open stream: Permission denied [/usr/local/apnscp/lib/Opcenter/System/Cgroup/Attributes/Cpuset/Cpus.php:78]
UNKNOWN: Error_Reporter::report()
INTERNAL REPORT: Missed controller site4 site4 [:]
0B. Error_Reporter::handle_error(32, "Missed controller site4 site4", null, null, Exception)
[/usr/local/apnscp/lib/error_reporter.php:1315]
1B. Error_Reporter::report("Missed controller site4 site4", ["site4", "site4"])
[/usr/local/apnscp/lib/log_wrapper.php:185]
2B. report("Missed controller %s %s", "site4", "site4")
[/usr/local/apnscp/lib/modules/cgroup.php:216]
3B. Cgroup_Module->_housekeeping()
[/usr/local/apnscp/lib/lservicelib8.pht:553]
4B. ListenerService\Daemon->do_housekeeping()
[/usr/local/apnscp/lib/lservicelib8.pht:436]
5B. ListenerService\Daemon->initHousekeeper()
[/usr/local/apnscp/lib/lservicelib8.pht:281]
6B. ListenerService\Daemon->start()
[/usr/local/apnscp/lib/lservicelib8.pht:169]
7B. ListenerService\Daemon->__construct()
[/usr/local/apnscp/lib/lservicelib8.pht:1456]
8B. ListenerService\Daemon::init()
[/usr/local/apnscp/lib/lservice.php:28]
Server 2
[root@web5 ~]# EditDomain --reconfig --all
WARNING: file_put_contents(): Write of 1 bytes failed with errno=34 Numerical result out of range
[/usr/local/apnscp/lib/Opcenter/System/Cgroup/Attributes/BaseAttribute.php:87]
0. file_put_contents("/sys/fs/cgroup/site1/cpu.weight", "0")
1. Opcenter\System\Cgroup\Attributes\BaseAttribute->deactivate()
[/usr/local/apnscp/lib/Opcenter/System/Cgroup/Attributes/BaseAttribute.php:53]
2. Opcenter\System\Cgroup\Attributes\BaseAttribute->activate()
[/usr/local/apnscp/lib/Opcenter/System/Cgroup/BaseController.php:120]
3. Opcenter\System\Cgroup\BaseController->create()
[/usr/local/apnscp/lib/Opcenter/Provisioning/Cgroup.php:135]
[/usr/local/apnscp/lib/Opcenter/System/Cgroup/Attributes/BaseAttribute.php:68]
0. file_put_contents("/sys/fs/cgroup/site1/io.bfq.weight", "0")
1. Opcenter\System\Cgroup\Attributes\BaseAttribute->write("/sys/fs/cgroup/site1/io.bfq.weight", 0)
[/usr/local/apnscp/lib/Opcenter/System/Cgroup/Attributes/BaseAttribute.php:58]
INFO : DNS not configured for `example1.com', skipping edit hook
INFO : DNS not configured for `example2.com', skipping edit hook
INFO : DNS not configured for `example3.com', skipping edit hook
INFO : Edited 5 sites in 2.99s (0.60s each) 5 succeeded, 0 failed, 0 skipped.
INFO : Edited 5 sites in 2.12s (0.42s each) 5 succeeded, 0 failed, 0 skipped.
Are cpu.weight and io.bfq.weight mandatory?
