- What version of apnscp are you running?
cpcmd misc_cp_version
old machine 3.2.45. target machine is a fresh install - Which version of RHEL or CentOS are you using?
cat /etc/redhat-release
rocky 8.10 - Can you reproduce this bug reliably? Provide steps. If not, provide steps to the best of your recollection.
I’m trying to move my sites to a new server using apnscp_php /usr/local/apnscp/bin/scripts/transfersite.php --stage=0 -s {{new site}} --all
The attempt fails for each site with the same error: FATAL: fatal(): unknown configuration value(s)reseller_id' located in servicereseller’ - Enable debug mode (
cpcmd config_set apnscp.debug true). Restart backend by hand,
cd /usr/local/apnscp/bin ; ./bin/apnscpd -f restart
This will give more information including backtraces.
Place the old server on edge.
Somehow the old server was on a tag instead HEAD detached at v3.2.45.2
Checked out master and the upcp and site transfer were successful.
Thanks!
