upcp pyenv issue
AlmaLinux release 8.10 (Cerulean Leopard)
TASK [/usr/local/apnscp/resources/playbooks/roles/software/pyenv/../pyenv-support : Clone pyenv repository] ***
fatal: [localhost]: FAILED! => {"changed": false, "cmd": ["/bin/git", "fetch", "--tags", "origin"], "msg": "Failed to download remote objects and refs: From https://github.com/pyenv/pyenv\n 61c0f25e..d04a081d master -> origin/master\n ! [rejected] v2.3.35 -> v2.3.35 (would clobber existing tag)\n"}
git describe
v3.2.45-44-gbfc3e3eb4
git branch
    (HEAD detached from v3.2.45.2)
    master
after upcp --reset
(wich failed with the same error as above)
cpcmd misc_cp_version
revision: bfc3e3eb423bda50780057c42a823ce77a505b70
timestamp: 1733516874
ver_patch: 45
ver_pre: 44-gbfc3e3eb4
On that server:
cd /usr/local/apnscp
git checkout master
upcp --reset ; upcp
For the other server, upcp should be adequate now.
I want to mention that i had a similar issue. After following the instruction here i started seeing the following error:
/usr/local/apnscp/build/upcp.sh: line 519: fatal: command not found
git pull origin master
Give that a go.
TASK [common/migrate : Reset pyenv repo] ***************************************
  cmd:
  - /bin/git
  - fetch
  - --tags
  - origin
  msg: |-
    Failed to download remote objects and refs:  From https://github.com/apisnetworks/pyenv
PLAY RECAP *********************************************************************
localhost                  : ok=7    changed=1    unreachable=0    failed=1    skipped=3    rescued=0    ignored=0
This keeps repeating
Run upcp - all set now?
