Im new to ApisCP and am currently running the trial version to explore and test if it suits my needs. I mainly want to use it to run wordpress sites. When using the 1 click install on wordpress I get an error and I can’t get it to work. The laravel and joomla 1 click installer work without a problem.
- Create a new site
- Make sure dns/ssl setting are good
- Create webapp and install Wordpress with 1 click install, version 6.7.1 with auto-updates and SSL enabled
Then I get an error:
ERROR: Lararia\Jobs\Job::handle(): Job failed - fatal error: Target file /var/www/html/wp-config.php does not exist
I also tried Joomla! and Laravel and they work but Invoice Ninja also gives an error:
ERROR: Module\Support\Webapps\App\Type\Laravel\Reconfiguration\Ssl::apply(): The environment file is invalid! Failed to parse dotenv file. Encountered unexpected whitespace at [Invoice Ninja].
ApisCP version:
revision: db498b0c7910e244038579b53024138efd49ec97
timestamp: 1734032028
ver_pre: db498b0c7
debug: true
Operating System: AlmaLinux 8.10 4.18.0-553.32.1.el8_10.x86_64
Perl version: 5.26.3
PHP version: 8.2
MySQL version (MariaDB): 11.4.4 (11.4.4)
PostgresQL: 16.6
It’s a fresh install without customization
