Message from wordpress installer
ERROR: Lararia\Jobs\Job::handle(): Job failed - fatal error: Target file /var/www/html/wp-config.php does not exist
Message from drupal:
ERROR: serial(): Module\Support\Webapps\ComposerWrapper::exec(): Failed executing Composer command ` -d memory_limit=-1 /usr/bin/composer --no-interaction -q require drush/drush': PHP Warning: Version warning: Imagick was compiled against ImageMagick version 1692 but version 1693 is loaded. Imagick will run but may behave surprisingly in Unknown on line 0 Your requirements could not be resolved to an installable set of packages.
ERROR: Drupal_Module::install(): Failed to install Drupal:
ERROR: DataStream::pipeline(): File_Module::set_acls(): no files to adjust!
Version: (should be edge-major)
# git describe
v3.2.45.2-15-gdb498b0c7
git branch
* master
In Contrast Drupal and some others work flawless. Anyone else seeing this kind of error?
